Введение
Before you begin, you will need a flathead screwdriver, thread, and a 175X7 size 18 sewing needle.
Выберете то, что вам нужно
Loop the threading through the two tension posts, making sure you stay in the grooves of the wheels.
Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right.
Weave threading through the working arm and have it ready to insert through the eye of the needle.
Again, keep the thread along the groove of the wheel before slipping it through the eye of the needle.
Using the flathead screwdriver, slide the needle up into the slot, with the indented side facing in and tighten until the needle cannot shift.
Еще один человек закончил это руководство.
