Jumper Angelsounds JPD-100S Battery Cable Replacement
Выберете то, что вам нужно
  1. Jumper Angelsounds JPD-100S Battery Cable Replacement, Motherboard: шаг 1, изображение 1 из 1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 2, изображение 1 из 2 Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 2, изображение 2 из 2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 3, изображение 1 из 1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 4, изображение 1 из 2 Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 4, изображение 2 из 2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 5, изображение 1 из 2 Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 5, изображение 2 из 2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 6, изображение 1 из 1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 7, изображение 1 из 1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Battery Cable Replacement, Battery Cable: шаг 8, изображение 1 из 2 Jumper Angelsounds JPD-100S Battery Cable Replacement, Battery Cable: шаг 8, изображение 2 из 2
    • Preheat soldering iron.
    • Locate the battery cable leads on the motherboard.
  9. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 9, изображение 1 из 2 Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 9, изображение 2 из 2
    • Use a soldering iron and solder vacuum to unsolder the battery cable leads.
  10. Jumper Angelsounds JPD-100S Battery Cable Replacement: шаг 10, изображение 1 из 1
    • Remove the battery cables by pulling them out of the motherboard.
Заключение
Safiyah Junaid
Участник с: 08/31/15
125 Репутация
1 руководство автора
Команда
USF Tampa, Team 6-1, Remmell Fall 2015 Участник USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
6 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 374
