Введение
Dripping water out of the joint between water reservoir and machine is an annoying issue. The water reservoir seal should be replaced. This ist a very easy fix, you even need not open the Impressa.
Выберете то, что вам нужно
Remove the water reservoir.
Turn the Jura on its side to have access to the bottom plate
The water connector is protected by a plastic cover, which is secured by two plastic rivets.
Use some pliers and squeeze the rivets tightly and push them up until they release.
Carefully pry up the plastic cover.
Insert the new gasket with the flat side facing up.
Give some food-proof lubricant to the new seal and replace it.
To reassemble your device, follow these steps in reverse order
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
