Введение
This a guide on cleaning and replacing keys on a KBD67 Lite R4 keyboard.
Выберете то, что вам нужно
Place keyboard on top of a flat table.
Remove keycaps manually or with a key cap puller, as demonstrated.
These images showcase the correct utilization of a key switch puller.
Remove switches either manually or with a key switch puller.
Use screwdriver to unscrew the eight screws on back of keyboard.
Use switch puller to take out stabilizers.
Once the stabilizers are unscrewed from the back, they can be removed from the PCB.
Place the plastic and foam cover on the bottom of the keyboard case.
Install stabilizers onto the PCB.
Screw where applicable.
Инструмент, используемый на этом этапе:Microfiber Cleaning Cloths$3.99
Align the key switch pins with the corresponding holes on the PCB.
Use the eight screws saved from the third step.
Plug the keyboard into a device of your choice and test its functions using appropriate software.
