Введение
Use this guide to replace the tweeter and driver of your KLH bookshelf speaker to make it last longer. Remember to disconnect the speaker before proceeding with any repair.
Выберете то, что вам нужно
Remove the front speaker mesh to expose the speakers. The mesh will lift off without the use of tools.
Once the mesh is removed, begin to remove the screws securing the small upper speaker/tweeter with a #1 Phillips head screwdriver.
Once the screws have been removed, pry out the small upper speaker with an opening tool.
After you have removed the speaker, disconnect the red and brown wires from the speaker.
For the larger bottom speaker, the same steps will be taken to remove the speaker.
Remove the four screws securing the speaker.
Once the screws are removed, remove the speaker by either prying up from the top, or pushing the speaker through by pushing on the bottom of the speaker.
2 участников успешно повторили данное руководство.
