Введение
Remove the bottom cover on a Karcher Carpet Cleaner BRC3015C 2018.
Выберете то, что вам нужно
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Use a 3 mm hex key to remove two bolts securing the bottom cover.
Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
2 участников успешно повторили данное руководство.
