Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace a faulty electronic control on your Kenmore 110 Washing Machine.
Выберете то, что вам нужно
Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
Lifting from the rear, remove the top panel.
Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
From the bottom, pull out and remove the component cover.
Carefully remove the three wire harnesses.
With a phillips head screwdriver, remove the three mounting screws.
10 участников успешно повторили данное руководство.
3 Комментариев
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
I am having the same problem. Did you ever find a fix?
