Введение
Use this guide to replace a faulty water pump on your Kenmore 110 Series Washing Machine.
Выберете то, что вам нужно
Carefully remove both wire harnesses connected to the pump.
Squeeze and pull back hose clamp.
Twist drain hose off of pump.
Using a 1/4" socket wrench, remove the three mounting screws.
Pull the pump out of place.
14 участников успешно повторили данное руководство.
9 Комментариев
i have a speed problem with my washer ...
please provide info on how to test the water pump once it's removed...
My clothes are still really wet.
Washer doesn't move doesn't do any thing it just hummus won't drain water
