Введение
The inner headband cover of the Kensington Hi-Fi Headphones 33137 covers the inside components of the headband. The inner headband cover must be removed during the few first steps of many repairs. This guide shows how to remove this piece.
Инструменты
Запчасти
Детали не указаны.
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
Use the screwdriver to pry the inner headband covering loose.
Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
