Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
Repeat the process in Step 1 to remove the right speaker clamp.
Turn the headphones so that the inner headphone cover is visible.
Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
Use the screwdriver to pry the inner headband covering loose.
Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
