Введение
If the CD/DVD drive in your Kenwood DNX571HD car stereo has stopped working, or has physically broken, follow this guide to remove the module and replace it with a new one.
Инструменты
Запчасти
Детали не указаны.
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
Lift up to remove the top casing.
Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Еще один человек закончил это руководство.
