Введение
If your Kenwood DNX571HD has been overheating, the cooling fan on the back of the Kenwood DNX571HD car stereo may have failed. Follow this guide to replace it.
Выберете то, что вам нужно
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
Lift up to remove the top casing.
Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
Remove the metal plate
