Введение
If you are having difficulties with the Kenwood DNX571HD GPS functions, the antenna may be faulty. Follow this guide to replace it.
Выберете то, что вам нужно
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
Lift up to remove the top casing.
Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
Remove the metal plate
Using a spudger, undo the clasp to disconnect the large white ribbon cable.
Remove the 5mm screw with teeth from the casing with a Phillips #1 screwdriver.
Remove the 5.5mm screw from the HDMI cable cover using a Phillips #2 screwdriver.
Remove the two 5.5mm screws from the back.
Lift the upper portion of the stereo free from the chassis.
Remove the two screws underneath the GPS connector.
Desolder the GPS connector.
To remove and reinsert the connector, on the top side of the board, use your finger to gently lift the metal plate to get enough clearance.
Еще один человек закончил это руководство.
