Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Pull the top of the front panel out and down to remove front panel.
Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
Lift up to remove the top casing.
Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
Remove the metal plate
Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
Remove the four 5.5mm screws with the Phillips #1 screwdriver.
Remove the two 13mm long screws with a Phillips #1 screwdriver.
Using a spudger, undo the clasp to disconnect the large white ribbon cable.
Remove the 5mm screw with teeth from the casing with a Phillips #1 screwdriver.
Remove the four 5mm screws with a Phillips #1 screwdriver.
Remove the 5.5mm screw from the HDMI cable cover using a Phillips #2 screwdriver.
Remove the two 5.5mm screws from the back.
Lift the upper portion of the stereo free from the chassis.
Remove the two screws underneath the GPS connector.
Desolder the GPS connector.
To remove and reinsert the connector, on the top side of the board, use your finger to gently lift the metal plate to get enough clearance.
Еще один человек закончил это руководство.
