Введение
If your screen has been damaged and needs to be replaced, this guide will provide the steps to remove the old screen and replace it with a new one.
Выберете то, что вам нужно
Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the main board.
Flip up the black clasp with the spudger to disconnect the large white ribbon cable from the main board.
Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the vertical board.
Carefully pull the ribbon from the clasp with the spudger.
Flip up the black clasp with the spudger to disconnect the large orange ribbon cable from the main board.
Push out the black clasp with the spudger to disconnect the small orange ribbon cable from the main board.
Gently push the ribbon out of the clasp with the spudger.
Using a pair of tweezers, gently pull up on the connector for the power cable to disconnect it from the main board.
Unscrew the two 4mm screws holding down the board that is standing vertically with a Phillips #1 screwdriver.
Pull up on the board to remove it.
Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
Unscrew the 4mm screw with a Phillips #1 screwdriver.
Remove the disconnected circuit board.
Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
Gently lift the board out of the casing.
Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
4 участников успешно повторили данное руководство.
