Kenwood DRV-N520 Dashcam Speaker Replacement
Выберете то, что вам нужно
  1. Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: шаг 1, изображение 1 из 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: шаг 1, изображение 2 из 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: шаг 1, изображение 3 из 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws from the device backing.
    • Remove the backing.
  2. Kenwood DRV-N520 Dashcam Speaker Replacement: шаг 2, изображение 1 из 3 Kenwood DRV-N520 Dashcam Speaker Replacement: шаг 2, изображение 2 из 3 Kenwood DRV-N520 Dashcam Speaker Replacement: шаг 2, изображение 3 из 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the copper plate.
    • Remove the copper plate from the housing. The motherboard and capacitors should now be visible.
  3. Kenwood DRV-N520 Dashcam Speaker Replacement: шаг 3, изображение 1 из 2 Kenwood DRV-N520 Dashcam Speaker Replacement: шаг 3, изображение 2 из 2
    • Use the screwdriver to remove the two screws holding the motherboard in place.
    • Before attempting to remove the board, disconnect the camera by removing the ribbon cable from its corresponding connection on the board.
    • To remove the ribbon cable, use a plastic spudger to gently apply pressure to the lever that secures the cable in place while simultaneously applying a light pulling pressure on the ribbon cable.
    • Disconnect the speaker connections (red and black wires) from the motherboard by applying pressure to the clip on its corresponding socket.
    • Once all connections have been severed, gently remove the motherboard from the device casing.
    • The speaker unit and corresponding mounting hardware should now be visible.
  4. Kenwood DRV-N520 Dashcam Speaker Replacement: шаг 4, изображение 1 из 2 Kenwood DRV-N520 Dashcam Speaker Replacement: шаг 4, изображение 2 из 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws from the speaker's mounting bracket.
    • Remove the speaker from the device.
Заключение
To re-assemble your device, follow these steps in reverse order.
NathanGoodwin
Участник с: 01/30/20
136 Репутация
1 руководство автора
Команда
ERAU-LAMOTHE-S20S14G1 Участник ERAU-LAMOTHE-S20S14G1
Repair Café
4 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 152
