  1. Locate the face-plate eject button.
    • Locate the face-plate eject button.
  2. Press the eject button with your forefinger. Remove the face-plate.
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Starting on the top side, pop the front panel frame out. Remove the face-plate frame.
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Use the plastic opening tool to pry open the tabs. Repeat on the opposite side.
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  6. Remove the front panel.
    • Remove the front panel.
  7. Use the Phillips #0 Screwdriver to remove the four screws.
    • Use the Phillips #0 Screwdriver to remove the four screws.
  8. Use the plastic opening tool to pry it open. Use the plastic opening tool to pry it open.
    • Use the plastic opening tool to pry it open.
  9. Lift and remove the motherboard to reveal the inside of the front panel. Lift and remove the motherboard to reveal the inside of the front panel.
    • Lift and remove the motherboard to reveal the inside of the front panel.
  10. Use the metal spudger to straighten out the six pegs to allow the removal of the LCD Screen. Use the metal spudger to straighten out the six pegs to allow the removal of the LCD Screen.
    • Use the metal spudger to straighten out the six pegs to allow the removal of the LCD Screen.
  11. Lift the LCD Screen to remove and replace it. Lift the LCD Screen to remove and replace it.
    • Lift the LCD Screen to remove and replace it.
Заключение
Steven Chov
Участник с: 04.10.2016
301 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 2-5, Cagle Fall 2016 Member of USF Tampa, Team 2-5, Cagle Fall 2016
USFT-CAGLE-F16S2G5
4 членов
Автор 5 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
За всё время: 425
