Введение
This repair might be needed when the buttons in the face plate become broken or lost.
Выберете то, что вам нужно
Press the ejection button on the lower left corner of the face plate.
Remove the face plate by pulling upwards and in the direction of the ejection button.
Separate the two halves of the housing by prying along the length of the device with a plastic opening tool.
Remove the 5.5 mm Phillips #00 screw.
Remove the clear plastic piece by carefully prying it away from the plastic housing.
Remove the gray rubber piece by pulling it upwards and away from the plastic housing.
Use the pointed end of a spudger to pry out the buttons.
