Введение
In this guide, you will replace the water reservoir. This is necessary if you want to clean the reservoir or if it does not hold water sufficiently. The water reservoir is transparent and is located on the left side of the Keurig machine.
Lift the Water Reservoir up. It should be easy to separate it from the main part of the brewer.
Почти готово!
Заключение
