Введение
Replacing the Puncture Needle is similar to the Handle Replacement, but requires a couple extra steps outlined below.
Выберете то, что вам нужно
Locate and remove the two 9.5 mm Phillips #1 screws.
Remove the plastic ring around the K-Cup Pack Holder
Locate and remove the two 9.5 mm Phillips #1 screws on the top of the puncture needle.
Squeeze and pull on the hose to remove it from the Puncture Needle
Puncture needle should now be exposed
6 участников успешно повторили данное руководство.
2 Комментариев
I will be completing this guide but where do you get the replacement puncture needles for this model??
John Lawson
