Введение
Replacing the Water Filter requires only a couple steps as outlined below.
Выберете то, что вам нужно
Remove the Water Reservoir Cap and the Water Reservoir from the brewer by simply pulling up and out
Remove the three 9.5 mm Phillips #1 screws that secure the small circular screen to the bottom of the water reservoir.
This circular screen has a rubber "O"-ring around the base. Use the plastic opening tool to pry off the rubber seal. Replace with undamaged seal.
2 участников успешно повторили данное руководство.
