Введение
Broken handle? Lid not closing completely?
This guide will show you how to remove and replace the brewer handle for the Keurig B70 Platinum if you're experiencing any problems with the handle. Before continuing with the guide, you're going to need a Phillips #2 screwdriver and T15 Torx screwdriver.
Выберете то, что вам нужно
Turn off and unplug the Keurig before starting.
Lay the Keurig on its back and open the lid.
Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
