Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replacing the Cold Water Reserve Arm is a fairly simple task that does not require a large time investment. Even beginners should be able to complete this replacement without the need for outside help.
Выберете то, что вам нужно
Lift the cold water reserve lid up to reveal its hinge.
Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Remove two 9 mm Phillips #1 screws.
The screws are located on the top of where the K-Cup would be.
Once you remove the screws, the top cover should come out.
You will then want to remove these screws which are the same size.
Once you get those removed, you are going to want to pull on the hose until it pops off.
Once the hose comes off, the needle will fall out by itself.
Remove two 14 mm Phillips #2 screws.
Remove two 12 mm Phillips #2 screws.
Lift the arm off the assembly. This will reveal the tank hole as shown.
Remove two 9.7 mm Phillips #2 screws.
Remove two 11.5 mm Phillips #2 screws.
Remove the cold water reserve arm's plug from the arm itself in order to allow access to the base screws.
Remove two 18 mm Phillips #2 screws.
Finally, detach the arm from the cold water reserve basin.
