Введение
In this guide we will show you how to successfully remove the K-cup holder.
Инструменты
Запчасти
Детали не указаны.
Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Почти готово!
Заключение
