Введение
This repair guide will demonstrate a way to remove and replace the handle on a Keurig K40.
Выберете то, что вам нужно
Unscrew one of the 2mm screws on the handle using a T15 screw head. Keep a firm grip on the device so it does not shift out of place.
Flip the Keurig over and unscrew the other 2mm screw using the same screw head. Keep a firm grip on the device to prevent it from shifting or falling.
Remove the lever by pulling it away from the Keurig.
Replace a new handle by putting the Keurig back together the same way it was taken apart.
Еще один человек закончил это руководство.
