Введение
This part is accessible from the top of the device. There is no need to remove the base plate or deal with the internal components. The function of this needle is to puncture the k-cup in order for water to flow through to brew the coffee.
Выберете то, что вам нужно
Locate the handle on top of the unit
Locate the two Torx head screws on the underside of the handle. Remove them with a T15 screwdriver
While looking upwards from underneath the Keurig, remove the two 8mm Phillips #2 screws from underneath the black plastic "shroud".
Remove the black plastic "shroud" by pushing inwards and then pulling upwards to disengage the plastic hooks that are not visible.
Remove the two 8 mm screws with a PH #1 screwdrver
Pull on the plastic tube to remove it
Pull out on the top component perpendicular to the top face as shown. It will pop out without too much effort.
2 участников успешно повторили данное руководство.
