Введение
Use this guide to remove or replace the baseplate of the Keurig K75 Platinum Brewing System. This allows the user to reach the internal parts of the Keurig B70 Platinum.
Запчасти
No parts specified.
  1. Before beginning the repair, turn off the brewer and disconnect it from any power source. Move the brewer so that the metal baseplate is easily accessible.
    • Before beginning the repair, turn off the brewer and disconnect it from any power source.
    • Move the brewer so that the metal baseplate is easily accessible.
    • Remove the five silver 4 mm Phillips #2 screws from the baseplate.
  2. Using a spudger, gently pry the metal baseplate from the brewer. Gently set down the baseplate.
    • Using a spudger, gently pry the metal baseplate from the brewer.
    • Gently set down the baseplate.
Заключение
Kristen Temnyk
Участник с: 24.01.2013
500 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 20-2, Maness Winter 2013 Member of Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 2,615
