Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will help walk you through the steps of replacing the needle of a Keurig Mini. To get into the device all you will need is a #1 Philips screw driver.
Запчасти
Детали не указаны.
  1. Lift up the handle of the Keurig Mini.
    • Lift up the handle of the Keurig Mini.
  2. Make sure to avoid the needles above and inside the K-cup because may puncture your hand Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier.  The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
    • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
    • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
  3. Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat. Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
    • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
  4. Pull the K-cup holder straight out.
    • Pull the K-cup holder straight out.
  5. Open the top lid of the Keurig. Pull directly outwards on one of the arms that holds the top lid in place.  It will take some force to get the arm off the peg.  Once one side is off, repeat the process on the second arm. Pull directly outwards on one of the arms that holds the top lid in place.  It will take some force to get the arm off the peg.  Once one side is off, repeat the process on the second arm.
    • Open the top lid of the Keurig.
    • Pull directly outwards on one of the arms that holds the top lid in place. It will take some force to get the arm off the peg. Once one side is off, repeat the process on the second arm.
  6. Lay the Keurig on its back with the water reservoir pointing away from you.
    • Lay the Keurig on its back with the water reservoir pointing away from you.
  7. Avoid the top needle as it may puncture your hand.
    • Avoid the top needle as it may puncture your hand.
    • Unscrew the two 9mm #1 Philips screws that hold the top plastic cover in place.
  8. Set the Keurig in an upright position with the front side facing you.
    • Set the Keurig in an upright position with the front side facing you.
    • Pull the cover off the top of the Keurig. It should come off easily with little force.
  9. Firmly grasp the hose and pull it off of the plastic nozzle.
    • Firmly grasp the hose and pull it off of the plastic nozzle.
  10. Unscrew the two  9 mm #1 Philips screws at the top of the device.
    • Unscrew the two 9 mm #1 Philips screws at the top of the device.
  11. Push down lightly on the nozzle that the hose was attached to. The plastic housing along with the needle should pop off without much force.
    • Push down lightly on the nozzle that the hose was attached to. The plastic housing along with the needle should pop off without much force.
Заключение
Еще один человек закончил это руководство.
Andrew Adriance
Участник с: 14.01.2014
1 848 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 17-1, Forte Winter 2014 Участник Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 членов
Автор 17 руководств
Один комментарий
This is great but where do I buy the top needle replacement part?
Jen - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 16
За последние 30 дней: 81
За всё время: 14,306
