Введение
This project will require taking off some bolts or screws that may be difficult to loosen. Although not required, an impact driver or impact wrench may be suggested. This is quite easy to follow but the individual steps may be difficult. If your car is older or live in a rainy place then the project may be difficult.
Выберете то, что вам нужно
Remove window crank handle using the handle removal tool using the orientations seen in the first and second pictures.
Use a sharp knife to cut the strip calk connecting the top half of the moisture shield.
Pull the moisture shield half way down.
Remove the door handle from the door frame.
Remove the wires from the door handle.
Put on your replacement door handle.
2 участников успешно повторили данное руководство.
