Kicker CXA300.1 Capacitor Replacement
Выберете то, что вам нужно
  1. Kicker CXA300.1 Capacitor Replacement, Capacitor: шаг 1, изображение 1 из 1
    • Remove the five T10 Torx screws from the housing.
  2. Kicker CXA300.1 Capacitor Replacement: шаг 2, изображение 1 из 1
    • Remove the two T10 Torx screws from the faceplate.
  3. Kicker CXA300.1 Capacitor Replacement: шаг 3, изображение 1 из 2 Kicker CXA300.1 Capacitor Replacement: шаг 3, изображение 2 из 2
    • Remove the six T10 Torx screws from the bottom.
    • Pull off the bottom.
  4. Kicker CXA300.1 Capacitor Replacement: шаг 4, изображение 1 из 1
    • Desolder the capacitor and remove.
    • Refer to iFixit’s soldering guide to reattach capacitor.
Заключение
Tim Keptya
Участник с: 04/12/18
546 Репутация
Автор 4 руководств
Команда
UW Tacoma, Team S1-G3, Liner Spring 2018 Участник UW Tacoma, Team S1-G3, Liner Spring 2018
UWT-LINER-S18S1G3
3 членов
Автор 4 руководств
Один комментарий
Are you out of your mind or was this a late April Fools joke?!? That is NOT how you replace a capacitor, all you did was tear one off the board and take pictures of the carnage.
To replace a through-hole or snap-in capacitor you need to remove the board from the heat sink and (de)solder on the under side. In addition, proper selection of your replacement parts is crucial to the long-term viability of your repair.
If you are replacing a leaky/ruptured capacitor (or in this case, one that’s been torn off the board by a caveman) it’s critical to thoroughly clean any areas of the board and all components that were exposed to the electrolyte. The electrolyte in electrolytic capacitors is corrosive and will destroy the circuit board if it is not removed.
Tim, I encourage a response. Lets get some dialogue going.
Matt - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 856
