Kid Galaxy Morphibians Explorer On/Off Switch Replacement
Выберете то, что вам нужно
  1. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement, Remove the Top Cover: шаг 1, изображение 1 из 1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: шаг 2, изображение 1 из 1
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: шаг 3, изображение 1 из 1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: шаг 4, изображение 1 из 1
    • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
    • Turn the RC car over to reach the six screws on the bottom.
  5. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: шаг 5, изображение 1 из 1
    • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
    • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
  6. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: шаг 6, изображение 1 из 1
    • Lift the top Cover off the car.
  7. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement, On/Off Switch: шаг 7, изображение 1 из 1
    • On the top of the inside cover you will see the back side of the on/off switch. Remove the two 7.2 mm Philips #00 head screws holding the switch in place.
  8. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: шаг 8, изображение 1 из 1
    • Gently pull the on/off switch off the inside cover.
    • Remove the positive (red wire) and negative (black wire) terminals from the bottom of the batter cover. Snip the wires using wire cutters.
    • Remove to freed on/off switch from the inside cover.
Заключение
Eric Studstrup
Участник с: 09/22/14
4 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-2, Hickman Fall 2014 Участник USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 членов
Автор 7 руководств
Один комментарий
In the last step, Step 8 second bullet. Could add a image of actually showing how its done.
Dishant Patel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 458
