Введение
This guide goes through the process to replace the ON/OFF Power and Wifi Switches on the First Generation Amazon Kindle.
Запчасти
Никакие детали не требуются.
  1. Slide the grey plastic cover laterally off the back of the device.
    • Slide the grey plastic cover laterally off the back of the device.
  2. Use a plastic opening tool to lift the battery on the side closest to the edge of the device. Unplug the battery from the device by pinching the white connector and pulling.
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Unscrew eight (8) Phillips #00 screws (3 mm).
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Start at one side of the device.  Use a soft plastic prying tool to separate the casing of the device.  Slowly work your way around the entire device. Avoid prying between the buttons and the device.  This could cause damage to the buttons.
    • Start at one side of the device. Use a soft plastic prying tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  6. Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield. Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  7. Remove the two (2) Phillips #00 screws (3 mm) which fasten the ON/OFF Power and Wifi Switches to the device.
    • Remove the two (2) Phillips #00 screws (3 mm) which fasten the ON/OFF Power and Wifi Switches to the device.
  8. Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the pointed-end of the spudger. The flap is connected via a hinge.  Once you lift the flap, it will stay up and the cable will be lose.  Remember to snap it back down during reassembly.
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the pointed-end of the spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the ON/OFF Power and Wifi Switch vertically from the device motherboard.
Заключение
Samantha Manning
Участник с: 04.06.2013
721 Репутация
Автор 6 руководств
Команда
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 8
За всё время: 1,348
