Введение
This guide will go through the process of replacing the SD Card Reader in the First Generation Amazon Kindle.
Выберете то, что вам нужно
Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
Unplug the battery from the device by pinching the white connector and pulling.
Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
Carefully lift the SD Card Reader vertically from the motherboard.
2 участников успешно повторили данное руководство.
