Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
To install a new keyboard into your Kindle 2 requires you to completely disassemble your device, but with this guide it should be fairly simple.
Запчасти
Детали не указаны.
  1. Lay the Kindle face down on a soft cloth to protect its screen. Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing. Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
  2. Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing. Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place. Remove the metal casing.
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Pry upward under the black tab with the spudger to dislodge the battery. Use your fingers to lift the battery out of the device.
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
  6. Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
  7. Use the plastic opening tool to wedge underneath the connection and gently pop  off the wire cap.
    • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
  8. Use your fingers to lift the left end of the wireless card. Pull the card out of the slot.
    • Use your fingers to lift the left end of the wireless card.
    • Pull the card out of the slot.
  9. Remove 16 screws from the midframe. Remove 16 screws from the midframe.
    • Remove 16 screws from the midframe.
  10. Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire. Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp. Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
    • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
    • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
  11. Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap. Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it. Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
    • Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
    • Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
  12. Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
    • Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
  13. Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device. Repeat Step 10.
    • Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
    • Repeat Step 10.
  14. Push your finger down on the last plastic ribbon.
    • Push your finger down on the last plastic ribbon.
    • Slide your finger away from the connector to remove the last ribbon.
  15. Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
  16. Grab the bottom corner of the motherboard and safely remove it from the Kindle.
    • Grab the bottom corner of the motherboard and safely remove it from the Kindle.
  17. Grab the bottom left corner of the keyboard.
    • Grab the bottom left corner of the keyboard.
    • Peel the keyboard off the device.
Заключение
Еще один человек закончил это руководство.
Dayna Scott
Участник с: 16.04.2013
892 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 12-32, Amido Spring 2013 Участник Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 27
За всё время: 1,719
