Введение
Use this guide to replace the SIM Card in your Kindle 2.
  1. Lay the Kindle face down on a soft cloth to protect its screen. Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing. Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
  2. Use a Phillips #00 screwdriver to remove the two 4mm screws from the metal casing . Use a Phillips #00 screwdriver to remove the two 4mm screws from the metal casing .
    • Use a Phillips #00 screwdriver to remove the two 4mm screws from the metal casing .
  3. Locate the three clips that hold the metal case in place. Use the plastic opening tool to push down and pry towards the metal casing to release each clip. Remove the metal casing.
    • Locate the three clips that hold the metal case in place. Use the plastic opening tool to push down and pry towards the metal casing to release each clip.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. For safety reasons, use a Phillips #00 screwdriver to remove the two 3mm screws that hold the battery in place.
    • For safety reasons, use a Phillips #00 screwdriver to remove the two 3mm screws that hold the battery in place.
  6. Pry upward under the black tab with the spudger to dislodge the battery. Use your fingers to lift the battery out of the device.
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
  7. Remove 16 3mm Phillips #3 screws from the plastic panel. Lift the plastic panel and place it away from the Kindle 2.
    • Remove 16 3mm Phillips #3 screws from the plastic panel.
    • Lift the plastic panel and place it away from the Kindle 2.
  8. Locate the SIM card slot above and to the left of the LAB126 Logo and beneath the Wireless Card. Push the SIM card in the direction of the "UNLOCK" arrow on the SIM card case.
    • Locate the SIM card slot above and to the left of the LAB126 Logo and beneath the Wireless Card.
    • Push the SIM card in the direction of the "UNLOCK" arrow on the SIM card case.
  9. Lift the now unlocked case up on its hinges to reveal the SIM card slot. Lift the now unlocked case up on its hinges to reveal the SIM card slot.
    • Lift the now unlocked case up on its hinges to reveal the SIM card slot.
Заключение
Dayna Scott
Участник с: 16.04.2013
673 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 12-32, Amido Spring 2013 Member of Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 10
За всё время: 3,066
