Введение
My Kindle 4 had a motherboard issue and did not start even after I changed the battery. Fortunately, I found a second Kindle 4 with screen damage to salvage a working motherboard and change it.
Although removing a damaged screen from a Kindle 4 is pretty difficult, changing the motherboard proves much easier. Every single part of the device is glued, but the glue is sensitive to heat and will not be such a bother.
Выберете то, что вам нужно
Follow the Screen Replacement tutorial up to Step 4
Open the back cover
Remove the front cover
Disconnect the battery
Disconnect all flex cables from the board
There are 4 connectors to unclip:
Right buttons
Left buttons
Screen
Battery
Unscrew the board from the back
3 Torx screws on this side
Heat the plastic piece to help unglue it
Turn the device and push the piece out through the casing
Unscrew board from the front side
That’s another set of 2 screws !
The board has no more screws left, but it is still glued to the casing
Use some more heat to weaken the glue
Lever the board to unglue
Then, remove it by sliding it out
Here is what it looks like with EMC shields removed
Don’t try to remove the shields on your new board, they are directly soldered, and you risk damaging the whole PCB.
If you have another device from which you extract the new motherboard, run steps 1 to 7 again
Place the new motherboard
Before closing it back, test the device
Replug all connectors, connect the battery last
The LED should blink green upon battery reconnexion
Try turning the device on
Unplug the battery again
Rescrew the board
Replug the battery
Reassemble the plastic piece holding the buttons, the front cover, and the back cover
Amazon apparently discontinued service for this model: the service will expect double authentication, which apparently is not implemented in the Kindle firmware.
However, you can still use your Kindle 4 with USB : it is recognized as mass storage, and you can load ebooks in PDF or MOBI format in memory.
Check out the open-source software Caliber to convert your files in a vintage Kindle-friendly format.
Еще один человек закончил это руководство.
