Kindle 7th Generation Motherboard Replacement
Выберете то, что вам нужно
  1. Kindle 7th Generation Motherboard Replacement, Front Panel: шаг 1, изображение 1 из 2 Kindle 7th Generation Motherboard Replacement, Front Panel: шаг 1, изображение 2 из 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
    i had a battery that wouldn't even last a full day in the end. by accident i let the battery fall below 10% charge and when turned on it only showed the battery icon. I fully charged it and now i am having no problems with it. what i think happened is it reset the batteries memory and that was the problem. worth trying anyway before buying a new battery.
    soupamanx - Ответить
  2. Kindle 7th Generation Motherboard Replacement: шаг 2, изображение 1 из 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
    What is the adhesive you are using resecure the screen? Would Tesa 61395 Tape work (4mm) or would this create protrusion?
    Camble Scott - Ответить
    Did that option work for you? I'm about to try and change my battery and don't have any idea on what backup adhesive to have
    Lagroth -
  3. Kindle 7th Generation Motherboard Replacement, Back Panel: шаг 3, изображение 1 из 2 Kindle 7th Generation Motherboard Replacement, Back Panel: шаг 3, изображение 2 из 2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
    You will break the newer vision of kindle just like this. there is a peg that connect the top center of the screen to the back case. Remove the black double sided tape in the center and push this peg back .
    Kyle Darnell - Ответить
    If you see black double sided tape at the top of your Kindle, as the commenter above did, you are on the wrong model—have a look here to see if this is your model: Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement
    Lipsmeyer - Ответить
  4. Kindle 7th Generation Motherboard Replacement: шаг 4, изображение 1 из 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
  5. Kindle 7th Generation Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 Kindle 7th Generation Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
    • Flip the screen over to face the motherboard and battery pack.
    • Use the blunted precision tweezers to gently unclip and detach the cable connecting the battery pack and motherboard.
  6. Kindle 7th Generation Motherboard Replacement: шаг 6, изображение 1 из 3 Kindle 7th Generation Motherboard Replacement: шаг 6, изображение 2 из 3 Kindle 7th Generation Motherboard Replacement: шаг 6, изображение 3 из 3
    • Use the tip of the spudger to flip up the small retaining flap on the copper colored zero insertion force (ZIF) connector.
    • Make sure to flip up the flap and not the connection itself.
    • Pull the cable from the connector.
    • No force is required to do this, as the name, ZIF, implies.
  7. Kindle 7th Generation Motherboard Replacement: шаг 7, изображение 1 из 2 Kindle 7th Generation Motherboard Replacement: шаг 7, изображение 2 из 2
    • Similar to the previous step, flip up the retaining flap on the white cable connector.
    • Pull the white cable from the connection.
    • During reassembly, make sure the retaining flaps for both the white and copper colored cable connections are secured. As these are zero insertion force connections, the cables could potentially slide out if this is not done.
  8. Kindle 7th Generation Motherboard Replacement: шаг 8, изображение 1 из 2 Kindle 7th Generation Motherboard Replacement: шаг 8, изображение 2 из 2
    • Disconnect the touch digitiser bridge cable by using your Spudger to lift up the white tabs on both connectors.
    • Use tweezers to pull out the cable.
    • The touch digitiser bridge cable is the one connecting between these two connectors.
  9. Kindle 7th Generation Motherboard Replacement: шаг 9, изображение 1 из 2 Kindle 7th Generation Motherboard Replacement: шаг 9, изображение 2 из 2
    • Use the T5 Torx screwdriver to remove the eight 3.0 mm Phillips Head screws.
    • Some screws have washers associated with them. It is important to keep track of the washers and remember which thread they came from.
  10. Kindle 7th Generation Motherboard Replacement: шаг 10, изображение 1 из 1
    • Remove the motherboard.
Заключение
4 участников успешно повторили данное руководство.
Michael Griffith
Участник с: 02/02/15
485 Репутация
1 руководство автора
Команда
Cal Poly, Team 6-28, Amido Winter 2015 Участник Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 членов
Автор 18 руководств
3 Комментариев
This doesn’t look like my 7th generation. Close but not quite the same. Does the motherboard have to be removed to replace the screen?
Shonna Partlow - Ответить
Anyone know where to buy parts? I’m struggling to find any
Adrianne - Ответить
yes this is Def not the same as my 7th gen but it's an 8 inch so maybe that's the difference.. all I see is 4 screws holding down the motherboard n I've removed them but still can't get the board loose.. it's like one side of it is held down under these plastic tabs that don't move..
Heather Hodge - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 54
За всё время: 6,693
