Kindle Fire Battery Replacement
Выберете то, что вам нужно
  1. Kindle Fire Battery Replacement, Back Case: шаг 1, изображение 1 из 3 Kindle Fire Battery Replacement, Back Case: шаг 1, изображение 2 из 3 Kindle Fire Battery Replacement, Back Case: шаг 1, изображение 3 из 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Where can I buy a battery for my kindle fire
    nannyto2 - Ответить
    Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
    vvenona1954 - Ответить
    Remember to remove any sd card first!!! Snapped mine in half.
    lucy_lady_bug - Ответить
    I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
    Kris Sanders - Ответить
  2. Kindle Fire Battery Replacement: шаг 2, изображение 1 из 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Mine has another plastic pc over the m.etal plate
    Keith Long - Ответить
  3. Kindle Fire Battery Replacement, Battery: шаг 3, изображение 1 из 3 Kindle Fire Battery Replacement, Battery: шаг 3, изображение 2 из 3 Kindle Fire Battery Replacement, Battery: шаг 3, изображение 3 из 3
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  4. Kindle Fire Battery Replacement: шаг 4, изображение 1 из 1
    • Repeat the process from the previous step to free the left battery cell.
    The CPU got extremely hot and just now getting repaired 5 days or so
    Kelli Sabashion - Ответить
    I can't get the battery to charge
  5. Kindle Fire Battery Replacement: шаг 5, изображение 1 из 2 Kindle Fire Battery Replacement: шаг 5, изображение 2 из 2
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
Заключение
80 участников успешно повторили данное руководство.
Phillip Takahashi
Участник с: 08/22/11
86 704 Репутация
Автор 87 руководств
12 Комментариев
I'm usually intimidated by electronics when it comes time to pull off the back or something, so this guide was invaluable in my efforts to replace the battery. I found a great price ($28) on a replacement Kindle battery here: http://www.primelec.com/atl-tablet-eread...
Thanks again
dscottpeterson - Ответить
great post, I came across http://bestbattery.biz/Amazon/189882-D01...
The batteries from bestbattery.biz tried and tested with us.
Kermit45 - Ответить
Used this guide to replace my battery. Sadly, it didn't fix the problem. The problem is with my charger connection. It is loose. I had hoped changing the battery and looking at the problem from the inside would resolve it. The charging connection is in it's own little housing. I considered opening the housing but I had no replacement parts to fix whatever may be wrong. I greatly appreciate the quality of this repair guide. There were no problems with tear down or putting back together. Thanks again!
Jan Bentley - Ответить
Some kindles have a battery connection that "floats". The problem can be alleviated by soldering the charging port. There is an excellent video on YouTube that shows step by step, the process for soldering the charging port. Hope this helps!!!
Gilbert Lane -
Kindle Fire will not charge and when I wiggle the cord to charge the Kindle the light comes on but doesn't stay on. Tried a different cord still does not work. Where can I get another battery for the Kindle Fire. Please let me know or any Barnes and Noble bookstore or Staples, or Office Depot store where I can find a battery. Thanks Melony
jrazz - Ответить
W here can I get a new battery for my kindle fire. My old battery takes two days to charge. Thank you. I am from Chennai,India.
Hema - Ответить
I successfully replaced the battery, and it works! But the charge indicator only goes up to about 90% and the charging light won't turn green no matter how long it charges.
Paul - Ответить
Easy Peary!! To remove the battery that is. Thanks!!!
Jane Elder - Ответить
Very helpful post. Thanks. Anyone interested in considering buying a refurbished kindle from amazon. Read some interesting facts here http://rodsmarketingsite.com/7-reasons-t...
Rodney Ragwan - Ответить
which kindel is the one showing mine does not have the round buttons it has the inset ones
Big Daddy - Ответить
Hi, I have a Kindle Fire 8 5th generation and changed the battery. Didn’t help. I use it only without WiFi and in Airplane Mode for reading and it still lasts only for about an hour and a half. It was also a very difficult to open the tablet as you can’t see the two halves.
Sara Agai - Ответить
I tried this to replace the battery but backed out because the pictures looked far different from my Kindle Fires inside and I was afraid of messing something it up. Still a really good guide.
Human Person - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 58
За последние 30 дней: 328
За всё время: 273,392
