Kindle Fire HD 10 Battery Replacement
Выберете то, что вам нужно
  1. Kindle Fire HD 10 Battery Replacement, Battery: шаг 1, изображение 1 из 3 Kindle Fire HD 10 Battery Replacement, Battery: шаг 1, изображение 2 из 3 Kindle Fire HD 10 Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • Pry open the case using the iFixit opening tool. Make sure to go around the whole case before removing the whole case.
    • Some force is required to remove the back cover. In order to remove the casing successfully, keep the clips holding the cover from "popping" back in.
  2. Kindle Fire HD 10 Battery Replacement: шаг 2, изображение 1 из 2 Kindle Fire HD 10 Battery Replacement: шаг 2, изображение 2 из 2
    • Remove the plastic yellow taping from the wire circuits using a pair of tweezers.
  3. Kindle Fire HD 10 Battery Replacement: шаг 3, изображение 1 из 1
    • With slight force pry off the cable connecter using a spudger.
  4. Kindle Fire HD 10 Battery Replacement: шаг 4, изображение 1 из 2 Kindle Fire HD 10 Battery Replacement: шаг 4, изображение 2 из 2
    • Remove the ten 4mm screws from the outsides of the battery with a Phillips #0 screwdriver.
    • Lift out the battery from its resting position using your fingers.
Заключение
10 участников успешно повторили данное руководство.
Jonathan Stewart
Участник с: 09/19/19
379 Репутация
1 руководство автора
Команда
5 Комментариев
I cannot open a SL056ZE.
I mean I opened it up to all around it, it lifts but there seems to be part of ‘blue’ plastic cover - internally - that is kind of locked into right side of PCB [looking at it with battery below !
Any ideas?
JoeBlog - Ответить
Probably amazon locking it because of their stupid repair practices, Is it possible to rip it off or unscrew it somehow and reattach it? Get back to me if that is a possibility
Alyssa Bell - Ответить
Two problems I have found so far. The first one is that the cover has some clips on the inside so you have to play with the cover until you can get them to release. Be careful as too much pressure will crack the screen. The second problem is that the battery is glued to the metal frame that you just removed the 4mm T4 Torx screws. Something that should take a few minutes has taken me a few days just to make sure I don't destroy the screen.
thermalone - Ответить
An addition to my previous post: I had to use a plastic kitchen spatula in order to separated the battery from the metal tray. It has two glue strips that were reused to hold the new battery pack in place. The old battery pack was totally destroyed and will be properly recycled. Now it's a struggle to get the case to mate with the screen and lock in place. so far only one side has mated properly. will keep trying until its done correctly.
I was thinking my battery may need changing as slow charging, but after reading all these comments, I may just buy a new tablet! May be cheaper than going to a shop to ask them to do it and they need it up.
Kathleen Hill - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 113
За последние 30 дней: 478
За всё время: 18,145
