Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide describes how to remove the camera from the Kindle Fire HD 6. You might need to remove your camera if the lens is scratched or dirty, or if you need to access the motherboard or screen.
  1. Place the device face down on a clean cloth or another smooth surface.
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Carefully separate the back panel from the rest of the device internals. Carefully separate the back panel from the rest of the device internals.
    • Carefully separate the back panel from the rest of the device internals.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  4. Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
    • Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
  5. Be careful not to damage the camera lens as you remove the camera. Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base. Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
    • Be careful not to damage the camera lens as you remove the camera.
    • Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
Заключение
Cassandra Beck
Участник с: 13.01.2015
849 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 70-4, Forte Winter 2015 Участник Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 722
