Kindle Fire HD 8.9" Battery Replacement
Выберете то, что вам нужно
  1. Kindle Fire HD 8.9" Battery Replacement, Screen: шаг 1, изображение 1 из 3 Kindle Fire HD 8.9" Battery Replacement, Screen: шаг 1, изображение 2 из 3 Kindle Fire HD 8.9" Battery Replacement, Screen: шаг 1, изображение 3 из 3
    • Insert a large plastic opening tool next to the Kindle's headphone jack.
    • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Move the plastic opening tool evenly around the Kindle, separating the two halves.
    • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
  2. Kindle Fire HD 8.9" Battery Replacement: шаг 2, изображение 1 из 1
    • Set the Kindle down on the rear case.
    • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
    • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
  3. Kindle Fire HD 8.9" Battery Replacement: шаг 3, изображение 1 из 3 Kindle Fire HD 8.9" Battery Replacement: шаг 3, изображение 2 из 3 Kindle Fire HD 8.9" Battery Replacement: шаг 3, изображение 3 из 3
    • Lift the retaining flap on the ZIF connector of the upper flex cable.
    • Gently pull the cable out of its socket.
    • This flex cable is delicate. Be careful not to crease or bend it while working.
  4. Kindle Fire HD 8.9" Battery Replacement: шаг 4, изображение 1 из 1
    • Separate the display assembly from the rest of the device.
    • When reassembling the device, align the two halves of the case before connecting the flex cables.
  5. Kindle Fire HD 8.9" Battery Replacement, Inner Metal Casing: шаг 5, изображение 1 из 2 Kindle Fire HD 8.9" Battery Replacement, Inner Metal Casing: шаг 5, изображение 2 из 2
    • Remove the following sixteen screws from the metal midframe on the rear of the device:
    • Four 3 mm Phillips screw (located in each corner of the device - noted in red in the diagram)
    • Four 3 mm Phillips screws (surrounding the ports - noted in orange in the diagram)
    • Eight 3 mm Phillips screws (located around the body of the midframe - noted in yellow in the diagram)
  6. Kindle Fire HD 8.9" Battery Replacement: шаг 6, изображение 1 из 2 Kindle Fire HD 8.9" Battery Replacement: шаг 6, изображение 2 из 2
    • Carefully remove the metal midframe.
  7. Kindle Fire HD 8.9" Battery Replacement, Battery: шаг 7, изображение 1 из 2 Kindle Fire HD 8.9" Battery Replacement, Battery: шаг 7, изображение 2 из 2
    • For easier handling, position the Kindle as shown.
    • Lift up on the silver ends of the black flex cable that lays across the battery.
    • Gently pull the black flex cable from the battery.
  8. Kindle Fire HD 8.9" Battery Replacement: шаг 8, изображение 1 из 1
    • Disconnect the orange button cable from its socket on the motherboard.
    • Don't remove the button from the device. It is adhered to the case and may tear during removal.
  9. Kindle Fire HD 8.9" Battery Replacement: шаг 9, изображение 1 из 3 Kindle Fire HD 8.9" Battery Replacement: шаг 9, изображение 2 из 3 Kindle Fire HD 8.9" Battery Replacement: шаг 9, изображение 3 из 3
    • Starting at the outside edge of the battery, use the flat edge of a spudger to separate the battery from the rear of the device.
    • Work carefully. Excessive force on battery may cause it to bend, break, or crack.
    • Move the spudger along each side of the battery, prying upwards with even pressure.
    • As the adhesive releases, push the spudger further underneath the battery.
    • Once half of the battery is detached, pry the other half in the same manner.
    • Remove the battery assembly from the Kindle.
Заключение
20 участников успешно повторили данное руководство.
Jesus Perez
Участник с: 01/11/13
1 007 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-16, Forte Winter 2013 Участник Cal Poly, Team 5-16, Forte Winter 2013
CPSU-FORTE-W13S5G16
5 членов
Автор 14 руководств
8 Комментариев
Great guide. Easy to follow! Step 1 was the hardest step. I had so much trouble getting the device open.
Racheal - Ответить
Holy heck was that a pain in the ass, but it seems to have worked. Thanks for the info.
jellin67 - Ответить
Can anyone help me? I have replaced the battery twice and also replaced the charging port and it is not holding a charge /won't charge! Any suggestions?
Luna Noir - Ответить
Same thing but the port is not bent but the battery has been replaced about 3-4 times! Any tips????????????
Matthew Muehlberger - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 76
За последние 30 дней: 252
За всё время: 71,409
