Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your Kindle Fire 8.9'' has cracked front glass or a damaged screen, use this guide to replace the entire display assembly, including the LCD display, touch digitizer, front panel, and frame.
Выберете то, что вам нужно
Remove the SIM card tray (if present in your model).
Insert a large plastic opening tool next to the Kindle's headphone jack.
Move the plastic opening tool evenly around the Kindle, separating the two halves.
Set the Kindle down on the rear case.
Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
Lift the retaining flap on the ZIF connector of the upper flex cable.
Gently pull the cable out of its socket.
Lift the retaining flap on the ZIF connector of the lower flex cable.
Gently pull the flex cable from its socket.
To reassemble your device, follow these steps in reverse order.
60 участников успешно повторили данное руководство.
21 Комментариев
Where are the rest of the instructions???? I now have a disassembled Kindle and no idea how to install the new screen!
At the end of every iFixit guide, next to the "I did it! Success!" button, there is a message that says "To reassemble your kindle, follow these steps in reverse order." However in some cases, there will be a slightly different message. In the case of this guide, the message says "To reassemble your kindle, follow these steps in reverse order. Just make sure that you successfully connect the two flex cables to each half of your kindle and that you then align the two halves on the side opposite the camera before reassembling it."
while you are at it, try replacing the battery for a better experience.
I did, checkout this battery for kindle here :
