Отремонтируйте ваше устройство
Обучение ремонту
Магазин
  1. Этот шаг не переведен. Помогите перевести
    Remove the SIM card tray (if present in your model). Insert a large plastic opening tool next to the Kindle's headphone jack. Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Remove the SIM card tray (if present in your model).
    • Insert a large plastic opening tool next to the Kindle's headphone jack.
    • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Move the plastic opening tool evenly around the Kindle, separating the two halves.
    • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
  2. Этот шаг не переведен. Помогите перевести
    Set the Kindle down on the rear case.
    • Set the Kindle down on the rear case.
    • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
    • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
  3. Этот шаг не переведен. Помогите перевести
    Lift the retaining flap on the ZIF connector of the upper flex cable. Gently pull the cable out of its socket. This  flex cable is delicate. Be careful not to crease or bend it while working.
    • Lift the retaining flap on the ZIF connector of the upper flex cable.
    • Gently pull the cable out of its socket.
    • This flex cable is delicate. Be careful not to crease or bend it while working.
  4. Этот шаг не переведен. Помогите перевести
    Lift the retaining flap on the ZIF connector of the lower flex cable. Gently pull the flex cable from its socket.
    • Lift the retaining flap on the ZIF connector of the lower flex cable.
    • Gently pull the flex cable from its socket.
  5. Этот шаг не переведен. Помогите перевести
    Separate the display assembly from the rest of the device.
    • Separate the display assembly from the rest of the device.
    • When reassembling the device, align the two halves of the case before connecting the flex cables.
Финишная черта
60 участников успешно повторили данное руководство.
Jesus Perez
Участник с: 11.01.2013
949 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-16, Forte Winter 2013 Участник Cal Poly, Team 5-16, Forte Winter 2013
CPSU-FORTE-W13S5G16
5 членов
Автор 14 руководств
Комментариев: 20
Where are the rest of the instructions???? I now have a disassembled Kindle and no idea how to install the new screen!
Lisa Comer - Ответить
At the end of every iFixit guide, next to the "I did it! Success!" button, there is a message that says "To reassemble your kindle, follow these steps in reverse order." However in some cases, there will be a slightly different message. In the case of this guide, the message says "To reassemble your kindle, follow these steps in reverse order. Just make sure that you successfully connect the two flex cables to each half of your kindle and that you then align the two halves on the side opposite the camera before reassembling it."
Ian Meeder -
I think Lisa is asking for instructions concerning LCD display unmount. I got the same issue
Marlon - Ответить
How do you put the screen on??????
Ally - Ответить
while you are at it, try replacing the battery for a better experience.
I did, checkout this battery for kindle here :
http://bestbattery.biz/Amazon/219010-Kin...
Kermit45 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 75
За всё время: 42,180
