Kindle Fire HD Battery Replacement
Выберете то, что вам нужно
  1. Kindle Fire HD Battery Replacement, Open the Kindle: шаг 1, изображение 1 из 3 Kindle Fire HD Battery Replacement, Open the Kindle: шаг 1, изображение 2 из 3 Kindle Fire HD Battery Replacement, Open the Kindle: шаг 1, изображение 3 из 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Lift up until you hear a slight popping noise.
    • Repeat along the perimeter of the device to release the clips securing the case halves to each other. Remove the back cover.
    • The Kindle Fire could possibly have tape on the inside. Check for tape before removing the back cover.
  2. Kindle Fire HD Battery Replacement: шаг 2, изображение 1 из 1
    • If your device has copper tape attached to the battery, carefully peel it off the battery.
  3. Kindle Fire HD Battery Replacement: шаг 3, изображение 1 из 2 Kindle Fire HD Battery Replacement: шаг 3, изображение 2 из 2
    • Locate the antenna cable connector which is easier to find if you look for the gold tipped black wire that surrounds the battery.
    • Lift and pull up the antenna connector and the antenna cable that surrounds the battery
  4. Kindle Fire HD Battery Replacement, Remove Screws: шаг 4, изображение 1 из 3 Kindle Fire HD Battery Replacement, Remove Screws: шаг 4, изображение 2 из 3 Kindle Fire HD Battery Replacement, Remove Screws: шаг 4, изображение 3 из 3
    • Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
    • Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
    • The 2 mm T5 Torx screw is located on the motherboard near the antenna clip.
    • If you aren't equipped with the T5 Torx screwdriver, you could try using your fingers, although it will be very difficult to remove it.
  5. Kindle Fire HD Battery Replacement, Detach Cable: шаг 5, изображение 1 из 2 Kindle Fire HD Battery Replacement, Detach Cable: шаг 5, изображение 2 из 2
    • Detach the plastic piece that connects the wires to the motherboard using the plastic opening tool.
  6. Kindle Fire HD Battery Replacement: шаг 6, изображение 1 из 1
    • Lift the battery out of the device with your finger or the plastic opening tool.
Заключение
39 человек успешно провели ремонт по этому руководству.
Matthew Hodgdon
Участник с: 03/03/15
1 366 Репутация
Автор 2 руководств
Команду
Sam Houston State, Team 11-2, Blackburne Winter 2015 Участник Sam Houston State, Team 11-2, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G2
3 членов
Автор 9 руководств
6 Комментариев
Help. During our removal of the battery, the red and black wires that run along the long edge of the battery pulled free of their plug. Now we can't get them reattached. Not sure about polarity either.
Marc - Ответить
Where can you get a replacement battery
Gerald Hotchkiss - Ответить
Easy peasy! The hardest thing was getting the back cover off (and back on). Our local electronic repair store refused to open the case for me (they’ll never get any business from me), so I asked my dentist to do it, and he did (and loved it). I can’t remember where I ordered the battery from; I just put the model number in a search engine and got several hits. The one I bought was new, cheap ($14), came in two days, and had all the tools with it! Thanks, ifixit; I’ll get a few more years out of this older one, which I use for crosswords puzzles and solitaire; you know, stuff you do in the waiting room. btw, I’m a 78-year-old woman.
Just Me - Ответить
Nice work, proud of you.I would have never thought to ask your Dentist.
Dano -
Je voudrais un tuto pour cabler un lecteur de carte DE sur ma kindle Fire hd
remon dramon - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 10
За последние 7 дней: 52
За последние 30 дней: 203
За всё время: 75,797
