Введение
Make sure your device is powered off before you begin. Then place the device screen down.
*Caution: Some devices may have tape holding the back on.
Выберете то, что вам нужно
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Lift up until you hear a slight popping noise.
Repeat along the perimeter of the device to release the clips securing the case halves to each other. Remove the back cover.
If your device has copper tape attached to the battery, carefully peel it off the battery.
Locate the antenna cable connector which is easier to find if you look for the gold tipped black wire that surrounds the battery.
Lift and pull up the antenna connector and the antenna cable that surrounds the battery
Locate and unscrew the four 3 mm screws using the Phillips #00 screwdriver.
Unscrew the one T5 Torx screw using the special T5 Torx screwdriver head.
Detach the plastic piece that connects the wires to the motherboard using the plastic opening tool.
Lift the battery out of the device with your finger or the plastic opening tool.
39 участников успешно повторили данное руководство.
6 Комментариев
Where can you get a replacement battery
Easy peasy! The hardest thing was getting the back cover off (and back on). Our local electronic repair store refused to open the case for me (they’ll never get any business from me), so I asked my dentist to do it, and he did (and loved it). I can’t remember where I ordered the battery from; I just put the model number in a search engine and got several hits. The one I bought was new, cheap ($14), came in two days, and had all the tools with it! Thanks, ifixit; I’ll get a few more years out of this older one, which I use for crosswords puzzles and solitaire; you know, stuff you do in the waiting room. btw, I’m a 78-year-old woman.
Nice work, proud of you.I would have never thought to ask your Dentist.
Dano -
Je voudrais un tuto pour cabler un lecteur de carte DE sur ma kindle Fire hd
Je suis technicien je veux cabler un lecteur SD sur kindle Fire HD qui n'a pas de lecteurs et me donner le schéma électronique pour cabler sur la carte mère il très possible de le faire de toute manière elle n'ai plus sur garentit merci des réponse des techniciens remon remondramon353@gmail.
