Введение
Use this guide to help you replace the Front Glass/LCD in an Amazon Kindle Fire HD 7".
Выберете то, что вам нужно
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
Carefully split/cut the copper tape (which protects parts of the motherboard from heat) with a razor blade to allow removal of the antenna wire.
Unclip the antenna wire from the motherboard.
Unclip the antenna wire from each clip on the battery case (until the speaker).
Remove four Phillips #00 screws and one T5 Torx screw which secure the battery in place.
The T5 Torx screw is located on the motherboard near the antenna clip. Remove it using a special T5 Torx screwdriver.
To remove battery, lift battery up and away from Kindle, and pull cable out of motherboard.
Flip up the covering/flap with your finger, and detach cable. Repeat for second cable. Also repeat for the other end of the long cable (attached to motherboard).
Remove the two screws which secure the board in place.
Lift and remove the board.
The camera pops out easily by lifting and gently pulling it up out of the connection.
Remove both screw which secure the flat metal to the gray casing.
Unscrew the clamp covering the small display cable.
Detach the three display/touch screen cables from the motherboard by pulling up the tabs until they snap off.
Cut the copper sheet between the motherboard and outer gray casing using a razor blade or something similar.
Remove all the screws from the motherboard and speakers.
Remove the motherboard and speakers from the gray casing.
Lift the gray tray from the side shown in the picture.
Peel the antenna off the black outer casing.
Remove the strip which touches the power and volume buttons.
The device is disassembled! Replace the Display/LCD.
17 участников успешно повторили данное руководство.
2 Комментариев
Good guide. Followed it and finally succeeded.
Some points
Step 5 - the camera need not be disturbed, though the screws holding the plate do need to be removed.There was a rubber surround to the camera hole which came loose and had to be put back before the grey plate went back.
Step 6 - the smaller of the display cables (lower left in the picture) is held by a clamp and the screw holding it, visible under the white wire, needs to be undone before the cable is popped off..
The replacement screen assembly I bought did not include the plastic surround. I had to use a spudger to split the 'main' plastic rim (with buttons) from the screen, and a sharp thin- bladed knife to separate the 'inner' rim from the glass part, to which it was firmly glued. The new screen came with adhesive strips, so I carefully cleaned the adhesive remnants off the inner rim, aligned it very carefully and let it stick together. The main rim then clicked back onto this, and I had the screen/rim assembly as shown in step 9.
Just updated Step 6 in regards to the clamp.
Yosef -
