Введение
Перейти к шагу 1 ↓The rear panel is the chocolate exterior in this Kindle Fire HDX 7” Wonder Ball, and needs to be removed first to get to the sweet inside.
Follow this guide to replace it, or remove it to get to the interior components.
Выберете то, что Вам нужно
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Wedge opening picks around the perimeter between the display and back case.
Work the opening picks around the perimeter until the two halves disengage from each other.
Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
