Kindle Fire Speaker Assembly Replacement
Выберете то, что вам нужно
  1. Kindle Fire Speaker Assembly Replacement, Back Case: шаг 1, изображение 1 из 3 Kindle Fire Speaker Assembly Replacement, Back Case: шаг 1, изображение 2 из 3 Kindle Fire Speaker Assembly Replacement, Back Case: шаг 1, изображение 3 из 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Where can I buy a battery for my kindle fire
    nannyto2 - Ответить
    Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
    vvenona1954 - Ответить
    Remember to remove any sd card first!!! Snapped mine in half.
    lucy_lady_bug - Ответить
    I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
    Kris Sanders - Ответить
  2. Kindle Fire Speaker Assembly Replacement: шаг 2, изображение 1 из 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Mine has another plastic pc over the m.etal plate
    Keith Long - Ответить
  3. Kindle Fire Speaker Assembly Replacement, Battery: шаг 3, изображение 1 из 3 Kindle Fire Speaker Assembly Replacement, Battery: шаг 3, изображение 2 из 3 Kindle Fire Speaker Assembly Replacement, Battery: шаг 3, изображение 3 из 3
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  4. Kindle Fire Speaker Assembly Replacement: шаг 4, изображение 1 из 1
    • Repeat the process from the previous step to free the left battery cell.
    The CPU got extremely hot and just now getting repaired 5 days or so
    Kelli Sabashion - Ответить
    I can't get the battery to charge
  5. Kindle Fire Speaker Assembly Replacement: шаг 5, изображение 1 из 2 Kindle Fire Speaker Assembly Replacement: шаг 5, изображение 2 из 2
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
  6. Kindle Fire Speaker Assembly Replacement, Speaker Assembly: шаг 6, изображение 1 из 3 Kindle Fire Speaker Assembly Replacement, Speaker Assembly: шаг 6, изображение 2 из 3 Kindle Fire Speaker Assembly Replacement, Speaker Assembly: шаг 6, изображение 3 из 3
    • Peel the tape on the upper-left IC that is securing the speaker cable.
    • Use the flat end of a spudger to push the speaker connector out of its socket.
    • Deroute the speaker cable.
  7. Kindle Fire Speaker Assembly Replacement: шаг 7, изображение 1 из 2 Kindle Fire Speaker Assembly Replacement: шаг 7, изображение 2 из 2
    • Remove the two 3.3 mm Phillips #00 screws securing the speakers to the Kindle Fire.
    • Lift the speakers out of the Kindle Fire.
Заключение
4 участников успешно повторили данное руководство.
Phillip Takahashi
Участник с: 08/22/11
86 704 Репутация
Автор 87 руководств
2 Комментариев
It was easier for me to start taking the back off near the speakers.
Thanks for the post ... very helpful!
Gregory - Ответить
I replaced the speakers and now my screen is black. I hear sounds but no picture. Any suggestions???
Ann Marie Marciano - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 6,191
