Kindle Paperwhite 1st Generation Case Replacement
Выберете то, что вам нужно
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: шаг 1, изображение 1 из 2 Kindle Paperwhite 1st Generation Case Replacement, Case: шаг 1, изображение 2 из 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
    I found it easier to start this step off with one of the Opening Picks found in the iOpener pack.
    NathanF - Ответить
    The glue on bezel started to peel the sticky back protective layer off the screen for me - managed to smooth it back down, although now have an unsightly crease. I would try to hold the screen down when you pull the bezel off to stop damaging the screen.
    Callum Rogers - Ответить
    This step is most time consuming. Take you time and try not to scratch the bezel :)
    Oleksii - Ответить
    Couldn't get the plastic spudger under the edge of the bezel. A right-angle X-Acto blade was a satisfactory tool here.
    dbrick - Ответить
    The glue was VERY difficult...I used a trick, from taking apart phones, and used a hair drier to loosen up the glue...worked like a charm.
    billkaris - Ответить
  2. Kindle Paperwhite 1st Generation Case Replacement: шаг 2, изображение 1 из 3 Kindle Paperwhite 1st Generation Case Replacement: шаг 2, изображение 2 из 3 Kindle Paperwhite 1st Generation Case Replacement: шаг 2, изображение 3 из 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
    On 3G version you will not have the top middle screw.
    BJones - Ответить
    Hello, the original battery is 1420m Ah and 3.7VDC, but the buttery you offer to sell is 1600mAh, is it right? there is no problem with different mAh? mi kindle is the amazon kindle 1est generation
    Paula Ponce de Leon - Ответить
  3. Kindle Paperwhite 1st Generation Case Replacement: шаг 3, изображение 1 из 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
    There are clips in the bottom of the case helping hold the midframe in. Lift the top of the midframe up enough to clear the black back piece and then slide up and out.
    BJones - Ответить
Заключение
2 участников успешно повторили данное руководство.
Anthony Nahal
Участник с: 01/25/13
60 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 3-33, Amido Winter 2013 Участник Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 членов
Автор 17 руководств
2 Комментариев
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Ответить
4 years too late but I found this
Pao-Tang Kao - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 17
За последние 30 дней: 74
За всё время: 9,169
