Kindle Paperwhite 2nd Generation Motherboard Replacement
Выберете то, что вам нужно
  1. Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 2, изображение 1 из 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 2, изображение 2 из 2
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 3, изображение 1 из 1
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 4, изображение 1 из 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 4, изображение 2 из 2
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 5, изображение 1 из 1
    • Carefully lift the battery and remove it from the device.
  6. Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: шаг 6, изображение 2 из 2
    • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
    • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
  7. Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 7, изображение 1 из 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 7, изображение 2 из 2
    • Gently disconnect the zif connectors.
    • Some of these connectors are very thin and fragile, handle with care!
  8. Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 8, изображение 1 из 3 Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 8, изображение 2 из 3 Kindle Paperwhite 2nd Generation Motherboard Replacement: шаг 8, изображение 3 из 3
    • Gently remove the motherboard.
Заключение
3 участников успешно повторили данное руководство.
Tyler Davis
Участник с: 09/15/16
1 574 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 11-2, Blackwell Fall 2016 Участник USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 70
За всё время: 3,197
